Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Oil type for troy bilt weeder 4 cycle model # TB575SS
    Scholar:
  • 47 Answers
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
Posted on May 09, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Are you asking about the oil for the oil compartment or are you asking what to mix with the gasoline. Four stroke motors do not require the addition of oil. Regular unleaded is fine. Most trimmers come with a small bottle of oil, but the manufacturer's site has all of that information available whenever you need it :)
Make sure that the motor is on a .level surface or positioned so you can see the window in the oil compartment and add oil slowly to make sure you don't overfill. The fill line is marked; it's in the center of the round window.
Posted on Jun 16, 2017
SOURCE:
What type of oil do I use in a Troy built 490 four cycle brush cutter
if its the 4 cycle use sae 30 weight high quality oil 2.3oz this does not go in the gas.
Jun 06, 2014 | Troy-Bilt Garden
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil goes in crankcase
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Mar 22, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Do you mix the gas and oil together with the Troy-Bilt4 cycle TB575SS. Lost directions. Thank you
No. You do that for a 2-stroke engine. Your engine should have oil in the crankcase and you just need to check the level of it and add gas to it like a regular lawnmower engine.
Sep 06, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What type and grade of oil is required. I have lost my manual and do not remember what oil is required. Troy model TB4SC gas blower.
Any 2 cycle oil will work. Then mix 1 gallon of gas to 1 container of 2 cycle engine, shake well and pour into your blower.
Aug 10, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Gas mix?
Straight Gas no mix for a 4 cycle.
May 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Trying to replace the head of the weeder with a new line system,
I cannot get the head of my craftsman 791050 head off to replace with a new line system
Aug 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
11,030 people viewed this question
Top Troy Garden Experts
Neil Hancock
Jay Finke
Jay Finke
lnbn1975
Are you a Troy Garden Expert? Answer questions, earn points and help others
