Samsung AS18A6RB Air Conditioner Logo
Anonymous Posted on May 08, 2010
Samsung AS09XLN air conditioner lights blinking
My samsung AS09XLN air conditioner(split unit)lights are blinking. Tried starting up from remote and from the air cond unit, still the same. At startup operations, will get the usual sound and then the lights will be blinking. The compressor or the aircond fan has not started. I have cleaned the filter on the top of the aircond unit and its still the same.
any solution to this would be greatly appreciated, or what are the possible causes?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6750
Points
13
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
  • Dewayne Pippin
    Dewayne Pippin Aug 20, 2014
    What about a kemore model 25370101010 window unit?It does the same thing.
Anonymous
Level 2:
New Friend:
  • Expert 38 Answers
  • Posted on May 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
38
Questions
0
Helped
43683
Points
128
Change the pipe sensor
1 Related Answer
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Dec 07, 2010
SOURCE: Lights are blingking
thermostat command to out door unit not there . Check your PCB
Samsung split system air conditioner. Switch on
Its probably to thermistor it is a black wire with a bulb on one end and the other hooks to the control board I would replace this first if this doesn't fix it probably be the control board.
Both of the green lights of my samsung as09xln
Try turning the power off for a few minutes and then turn it back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
2answers
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
2helpful
2answers
LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Samsung AS-0914ER split system wall air conditioner
Here are different kind of unit with there manual button location, hope this may help.
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
