Nokia 6270 Cellular Phone Logo
Posted on Mar 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card. i have a problem when i insert my sim it says that is no sim card inserted
  • 8 more comments
  • angro May 12, 2008
  • Anonymous Mar 14, 2014
    how to insert sim card into alcatel 3003G
    insert a sim card
  • Anonymous Mar 15, 2014
    How to insert SIM Card into Samsung E1190
  • Anonymous Mar 21, 2014
    iv inserted my sim card into my new phone and have no service
  • Anonymous Mar 25, 2014
    WHat type of sim card does this phone take?
  • Anonymous Mar 27, 2014
    when i insert my sim card it say sim card not valid but it is good in an other phone
  • Anonymous Mar 30, 2014
    Insert a SIM card
    Insert a SIM card
  • Anonymous Mar 31, 2014
    It's a piece of ****!
Thx_nb
Level 2:
  • Expert 242 Answers
  • Posted on Mar 27, 2008
Thx_nb
Expert
Level 2:
Answers
242
Questions
0
Helped
505925
Points
748
Make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1310
Points
Put two layers of paper between SIM card and SIM holder to make it a tight hold.It solves your problem.
4 Related Answers
MOBILECARE
  • Posted on May 04, 2008
SOURCE: Insert SIM Card
Anonymous
  • 7752 Answers
  • Posted on Jan 06, 2008
you need to get a new main board.....or you can take it to a mobile store tech and have the phone fully service.
But the best solution would be to buy a need mobile....most time when a mobile gets wet......it's more of a 50/50 chance that it will work properly again.
Anonymous
  • 495 Answers
  • Posted on Nov 26, 2008
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Anonymous
  • 324 Answers
  • Posted on Mar 28, 2010
SOURCE: phone is showing insert sim card.
please reset to factory default
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Hi i have a samsung SCH-W339 mobile the problem is i have inserted many sim cards but it displays limited service instead of displaying the sim name and i cant make outgoing calls neither i recieve...
1. Your sim card is not in the right position. Take out your battery and your sim card. Make sure it is in the right position. Also make sure no dust or dirt where the sim card goes. Put the sim card back in your phone and battery. Turn it on. See if the insert sim card goes away.
2. If it goes not, then you will need a new sim card. Go to your local service provider store to get a new one.
Mar 25, 2011 • Cell Phones
My proble is i insert sim in mobile massage show please insert sim. my mobile model is m200 samsung
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
You `can contact a skill personnel for help.
Have a nice day.
1helpful
2helpful
Insert sim
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
5helpful
2answers
Says insert sim card when there is one in it
Likely Causes:
cheers.
5helpful
2answers
SE K750i displaying 'insert sim' even though sim is inside.
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it. for any queries mail to [email protected]
SE k750i is displaying insert sim even though sim is inside.
well... seem like you phone has got locked from the network may be accidently in case of stolen better check you service provider and if they say every thing is fine try to flash your mobile .it has some perticular number to flash it try these number *#7780# (password 12345)
Sep 01, 2007 • Nokia 3200
115helpful
29answers
Insert SIM Card
Oct 30, 2006 • Nokia 3200
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
