Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Mar 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
Hello, I'm hoping someone can help me figure this one out. I have a Front Loader Whirlpool Washing Machine AWM312/3 that will do everything except for the spin cycle. I have also noticed that the door does not stay locked for 2 minutes after it finishes it's cycle.
Can anyone help me with this.
Sam.
  • 2 more comments
  • sammi1 Mar 28, 2008
    Hi, thanks for your fast response. I don't have the service manual for the machine. I have had a look at the back of the machine and notice that it is belt driven. But, if you could post me the link that would be great!!
    Thanks,
    Sam.
  • Anonymous Aug 22, 2008
    manual for whirlpool awm312
  • Anonymous Mar 31, 2014
    Door of front loader is jammed shut agter end of wash. I sude to be able to get it to open when this happened occasionally by giving the door a bit of a thump with my hand. Has not responded this time to this treatment.
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Mar 27, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1722979
Points
23750
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1024
Points
I had the same problem, caused by a broken heating element in the door lock assembly. The bimetal strip will not heat up, there is no door lock delay, and there's no spin cycle.
Here's a link to an AWM 312 manual:
http://monitor.espec.ws//files/awm312_3_166.pdf
How do you get to the washer belt? I think it is not spinning. I think it came off the pulley.
Is your machine a front,or top loader, if top loader the most typical problem will be the motor coupler,Is it makes a clunking noise that makes a think the belt has come off? if yes noisy watch this youtube video and it will show how to get to and replace coupler.
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5453897861&kw=washing%20machine%20coupler
i hope my answer helps you to figure out what is wrong with your washer,
Gene
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
Washing machine displays drain blocked - where is the filter on my front loader A60D4066
Hello there.
There are three screws are on the very bottom of the washing machine. There is a kick plate underneith the door and below that plate there are 3 (hex) screws. Once you take the plate off, there should be a filter right before your eyes. Whirlpool makes it easy to access it.
Thanks for your inquiry and using fixya. Hope this helped :)
3answers
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
2answers
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
2answers
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
1helpful
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
