I have an older model ST27S3. What is the code? The A/V inputs are in the front ane back of the set but no channel will show the DVD and I don't have the remote. What can I do?
SOURCE: Input
Use a RF Modulator. This will allow you to connect the dvd to the antenna jack of the tv.
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
SOURCE: AV input selection without a remote
Depending on the model of the tv, you could scroll ch dn past ch 2 and you should cycle through your inputs. if that doesn't work try holding down the two vol buttons on the tv. that could access the menu for the tv
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
