Bij het afdrukken van een foto hapert de printer, geeft een klikje, stopt het printen en krijg ik in rode tekst de foutmelding 5100. Hoe kan ik dit probleem oplossen
AnonymousMar 21, 2009
When i try to print the Service error 5c00 comes and locks me out on printiingWhen i try to print the Service error 5c00 comes and locks me out on printiing
everytime I try to print I get an 5C00 error message which also states to turn off computer and cancel print queue. this doesn't do a thing.. What does this error code actually mean and how do I get my printer functioning? everytime I try to print I get an 5C00 error message which also states to turn off computer and cancel print queue. this doesn't do a thing.. What does this error code actually mean and how do I get my printer functioning?
Power the printer off.
Clear the print queue.
Power printer back on. And print something easy, like an email.
If that works, try printing the page that caused the error. If the 49 comes back, it's that document.
Do what Deepak says.
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again. Printer Properties cannot be displayed. The print spooler service is not running. Printer cannot be removed. The print spooler service is not running. Windows cannot print due to a problem with the current printer setup. (When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE. 2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES. 3) Locate and highlight the PRINT SPOOLER on the list of Services. 4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Hi!
Resolution:
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Resolution:
is stopped.
Resolution:
SPOOL.SVC
Resolution:
SPOOL.SVC
buoi
Error 5C00 when I try to print. There is nothing blocking the tray.
grinding noise
