I have a corrupted audio Wave file in my scandisk card when I used Tascam DR-100. I recorded for about 40 mins and when I switched the Tascam on again and tried to play the file, it says: File Error. When downloading the file by card reader, the file is only 30k and doesn't play. Help
You should be able to view the file on a computer. Select the file and delete it. Presumably there was an error after the file was recorded and all you probably have is the file name and a shell of a file. Hence it being only 30K.
There is nothing you can do with the file. And whatever you recorded was lost.
A 40 minute wave file would be massive. Try recording as MP3 for long files. You might be OK at 3 to 6 minutes with a WAV file.
SOURCE: tascam US-122 USB Audio/MIDI interfaces driver
the software is made by Steinberg and uses ASIO drivers that are at the address i gave you http://www.tascam.com/details;9,15,69,19.html
works fine on my XP machines
SOURCE: tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
SOURCE: power cut out on tascam x9
Since nothing else is working, the cooling fan is probably powered by AC at line voltage.
The power supply that feeds the electronics has failed but it may not be catastrophic; it might just be an internal fuse that has given up from metal fatigue.
Each time current flows when powered up, the delicate element expands and then contracts when the power is turned off.
Some fuses have a zig-zag crimp in the element that helps delay the eventual death.
With the unit unplugged, remove whatever screws you find on the back or bottom of the mixer so you can peer inside.
If you are lucky, you may find the fuse in a clip or otherwise plugged in.
There will definitely be one in the incoming AC line although if the fan is running, this one may be OK.
There could be one (or more) fuses on the DC side that directly services the circuitry.
Fuses come in a variety of cases; they can be cylindrical of glass or ceramic bodies with metal caps on the ends and of varying lengths.
Others may be vertically mounted smaller cylinders plugged into or soldered (bad) to the board.
Some are nearly indistinguishable in size and mounting from several other types of parts; these though, will not have other than simple text on the part while the others will have more complex markings.
If you find and replace fuses, buy two so that an eventual tech doesn't have to grub around to find one.
If you replace any fuses and they fail again, DON'T proceed. You may damage the unit further and not help anything.
At that point, you need to turn it over to a tech.
SOURCE: Can't import song from PC to DP-02 Unit and the Manual STINKS!!!!!
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
SOURCE: Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
