Question about Polycom PCY220016000001 SoundStation2 Voice-Conferencing Telephone with 3 Microphone Connections
Polycom soundstation2 not picking up the line
We have a VOIP system, dial 9 to call out, the phone plugged in with the polycome works fine but the actual device does not. Any help is greatly appreciated.
Mujhe gprs ki setting krwani hai
Posted on May 09, 2010
SOURCE:
My Duo has dial tone, I can dial out, and it works fine. But when anyone calls me they immediately get an automated message to the effect "the number you dialed is not a working number, please hang-up and...
This is a problem with the your VOIP carrier failing to translate and switch incoming calls to your device. Contact them and describe the problem and they should be able to fix it fairly quickly.
Mar 06, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
Hi, Does polycom IP sets support "LIFE DIAL PAD " function ?
Sorry to say but polycom IP sets does not support LIFE DIAL PAD. You can check that on the user manual if you have it with you.
Mar 23, 2010 | Computers & Internet
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
No Dial tone on my DECT 2882
Everything is fine now.  Turns out the problem was not with the phone at all, but somewhere in the tangle of connections from our high speed internet modem to the router to the VOIP device.  Resetting all three of these fixed it.
Jun 11, 2009 | Uniden DECT 6.0 Cordless Telephone...
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
For incoming calls, the caller cannot hear me for 2-10 seconds after I pick up
You've got an IP issue somewhere in your setup. It sounds like the call is being lost and then the phone is querying the DNS server to find out where it should be looking for the call. Do you have a VOIP server name or it's IP address in the setup? Are you using DHCP or manually assigning IP addresses? If the VOIP server is not on a static IP, I would fix that first. Post back here the answers and we can look at it further.
Aug 04, 2006 | Polycom SoundPoint IP 501 IP Phone
Polycom PCY220016000001 SoundStation2 Voice-Conferencing Telephone with 3 Microphone Connections  Logo
368 people viewed this question
Top Polycom Lands Phones Experts
Joseph Wright
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
