Question about Canon FS200 Flash Media Camcorder
My canon don't power on with a battery but power on with a charge can you help my to now what is the bad fuse? thank
  • 321 Answers
Try a new battery pack or let your's charge for 12 hres
about ;its seems that the battery pack you have is low in charge;because if its works with the chargerit should works with battery;about the bad fuse if it was the problem ,the camera will not work at all,
and that is a big problem that fuse is inside the camera on the pwr board,
hope that will help.
Posted on May 07, 2010
Testimonial: "thank you i will try"
    Guru:
  • 29 Answers
One of the cells in the battery may be bad (too weak to power the lens motor)
If you know someone that has the same camera and could borrow the battery to check wether some problem with your canon battery pack or not.
otherwise you can try a new canon camera battery replacement
http://www.sales-battery.com/digital-camera-batteries/canon.htm
http://www.global-battery.co.uk/digital-camera-batteries/canon.htm
CANON np-e3 battery
CANON NB-5L Battery
CANON BP-511 Battery
CANON NB-3L Battery
Posted on Jun 04, 2010
SOURCE:
No power in Samsung Q45 laptop
BATTERY IS BAD COULD BE CAUSED BY LEAVING AC ADAPTER PLUGGED IN ALL THE TIME ORDER NEW BATTERY COST LOW ON EBAY AROUND 20 BUCKS
Jul 23, 2017 | Samsung Q45 Notebook
Daughter called me ..car wont start. checked battery at Autozone...it is good. someone stopped to help them and bang on startere and it starts up. Bad starter. Starter replaced. Next day daughter...
it sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
Sep 02, 2011 | 2000 Oldsmobile Intrigue
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Craftsman 24 hp 42 mower turn key will not start no power check the fuse good battery 14 volts also turn light switch on no lights ? thanks
It sounds like either the battery has failed and no longer has enough power in it or else the battery ground wire, or power wire have become disconnected, the easiest way totest the battery is to run jumpers from the battery posts to the headlights (it does not matter which wire connects where as long as all other wires are removed from the lights)and see if the light, light up and if so how bright, if it does not the battery is not holding a charge and will have to be tested to find out if it is bad or the charging system on the tractor is bad, If they light then the next thing is to connect jumper cables from the battery to the starter solonoid and ground, following color code (positive to positive, negative to negative)and then try to start it, if it does there is a break or something is disconnected between the battery and the starter solonoid. If it does not start then most likely the starter is in need of replacement. Hope This Helps Don
Nov 10, 2009 | Craftsman Garden
No Power
does the camera work with the a/c power adapter?
If not then it could be something internal.
But if it works with the adapter, your batteries are bad or your battery terminals are dirty.
But just to be safe I would replace the back-up battery which is locate in the screen pocket of the camera. its a CR-2025 Nickel Cadmium battery
also I don;t know if you have a manual but here is a link to one.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=165&modelid=7512#DownloadDetailAct
Scroll down on the page for manuals
Good Luck
Jun 01, 2009 | Canon GL2 Mini DV Digital Camcorder
Will not power on or charge
This is a common issue with the sd1000 1 of 4 things can be wrong bad battery, blown fuse, or bad battery door switch or a bad main board. repair on your camera run any where from 45.00 to 90.00 to be repaired.
May 26, 2009 | Canon PowerShot SD1000 Digital Camera
Camera Shutting Down
Did this for the same problem on the PowerShot A570 IS and it worked wonderfully (thanks to other poster): For the PowerShot A 430: Take out the batteries, then hold down the power button for 30 seconds or more, then reinstall the batteries. Problem solved!
Feb 28, 2009 | Canon PowerShot A430 Digital Camera
Canon ZR500 no Charge light
From what ive been told, you might have a blown fuse. Unfortunately it is just any regular fuse its a micro fuse. It is at the edge of the motherboard with the etching H or K there are 4 of them. You can test to see if there is conductivity, if not than it could be the fuse, you can replace it or try to solder over the fuse...that would be dangerous but your camcorder will work until excess current fries it. IF not it could be a loose circuit.
Dec 03, 2007 | Canon ZR500 Mini DV Digital Camcorder
Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Canon A75 won't power on
The only advice I can give is to check for a fusible link close to where the battery cables connect to the PCB. Look for a component with an F prefix eg f1001 or f001. I never desolder the fuse if it's open circuit, I just break a glass type fuse and solder the wire across the surface mount component. Just make sure the fuse wire is the same value as the original.
Jun 15, 2006 | Canon PowerShot A75 Digital Camera
Canon FS200  Flash Media Camcorder Logo
394 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
