Power Acoustik LT-980/2 Car Audio Amplifier Logo
Posted on Mar 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Protection mode my amp powers on and the light is green and it even gets my subs bumping a little bit, but then i go to turn up lowpass, bassboast and crossover and my amp instantly goes into protection mode. any solutions to this?
  • Ricardorl Apr 01, 2008
    Hey, im having the same trouble. Id disconnect all speaker wires from the speaker terminals of the amp. Then, when it powers up again, the amp goes into protect mode and i didnt connect the speaker wires yet.
    The amp dont shuts down, but the light is orange (Not green or red completely). And if i connect the speaker wires again, make loud noises when even if i dont move the RCA cables where they plug into the amplifier.
Anonymous
Level 3:
  • Master 631 Answers
  • Posted on Mar 29, 2008
Anonymous
Master
Level 3:
Answers
631
Questions
Helped
237702
Points
1200
Disconnect all speaker wires from the speaker terminals of the amp. If it powers up and doesn't go into protect when you increase the settings, the wiring needs to be checked. If it still shuts down, the amp may need to be repaired.
Does it shut down or make loud noises when you move the RCA cables where they plug into the amplifier?
Trying to Hook up subs and amp to my stock stereo have re checked everything and had a friend check to just in case but everything is good and working order
check you remote wire to test unplug your subs and turn on system if protection mood come one your audio output may have problem''if noting happen connect back your your subs if the protection comes back; you sub wiring have to be check or they are bad'
1helpful
2answers
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
1helpful
2answers
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
HiFonics txi4008 not working, partially lighting up
Sounds like your amp has some power supply compents shorted out. Maybe some of the power mosfets are shorted and your only getting a little bit of power. That why only the H is lighting and as far as the green light, it don't take much for it to turn on. If it was major it would go into protect mode but it is'nt. I repair amps for a living and I'm the cheapest you'll find. But if you know about electronics and think you can take a crack at it, check it out. Becareful you could do more damage. Let me know if your interested. [email protected]
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
1helpful
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
2helpful
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Amp green then red light then nothing problem please help
It sounds like the output transistors have failed. To eliminate other possible problems, read through the following page.
Troubleshooting - Amp in Protect Mode
Let me know if you have any other questions.
3answers
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
