HTC G1 Logo
A
Anonymous Posted on May 06, 2010
G1: Well I cut my phone and the G1 logo appeared then ...
Well I cut my phone and the G1 logo appeared then it disappeared and I took my battery and sims card and did a reset on my phone but the screen is still black everytime I cut it on
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on May 06, 2010
Anonymous
Expert
Level 2:
Answers
32
Questions
0
Helped
17452
Points
169
YOU MAY NEED A NEW "FLEX CABLE" OR LCD..THE FLEX CABLE HOLDS THE LCD TO THE BOARD AND ESPECIALLY WITH SLIDE PHONES LIKE THE G1 THEY SOMETIMES COME LOOSE OR GO BAD OVERTIME FROM SLIDING THE PHONE UP AND DOWN TO ACCESS KEYBOARD. CHECK YOUR AREA FOR A TECH.
1helpful
Htc g1 problem to start-up
try xdadevelopers.com.plent info there
Phone not loading g1
You may need to wipe the factory setting. To do so, Turn Off the cellphone, now keep on holding the Home button and turn on the cellphone. It go to the recovery console, now select WIPE or press the short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
1helpful
Phone doesnt come on completely
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
When i turn on phone after android logo appears screen turns blank and phone will not turn off you have to take battery out
Try getting into recovery mode. Hold down home and press power. Keep holding home down while the phone boots. Can you get into recovery mode? You can just pull the battery after testing this.
You can also try holding "menu" while booting. This should put you in "safe" mode. If this works, then use the settings menu to do a factory reset and reboot.
1helpful
2answers
Water Damage T mobile G 1
Make sure that you take the battery and SIM out immediately. Find some desiccant and put it in the desiccant overnight.
Here are some other tips:
http://yourmonstersofmobile.com/how_to_for_cell_phones/dropped_your_cell_phone_in_water_this_might_help.html
2helpful
2answers
Forgot my gmail account,cant open my phone coz of security lock
Press and hold Home key+ Power key, G1 will boot to restore mode. Wait until Android logo appears, open key board and press "left Alt+ W. There is an exclamation icon appears, wait for phone reboots again. After that, user can add new Gmail account.
Regard!
Aug 22, 2009 • HTC G1
6helpful
2answers
G1 keeps turning off by itself
g1 keep cutting off when im using the phone and turns it on and it cut back off and after charge phone it work right for a minute and turn back off
Won't turn on... just keeps flashing
Either the contacts to the battery aren't lining up correctly or it just needs a new battery. OR the charger isn't charging the battery.
2helpful
2answers
N73 hangs while starting up
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
