VA1703wb... Monitor beeps when I turn on the pc and shows the usual startup screens the beep is fairly long then after the beep the screen goes completely black... when I turn off then turn on the monitor same thing happens beep/shows the screen then after the beep goes black entirely..I tried some basic things like power cycling the monitor, checking cables/reconecting cables and connecting to another pc/laptop still same thing beeps fairly long while showing the screen then after the beep goes completely black...
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
