Kindly try the following...
- remove the battery and power on the laptop using power cable.
- issue not fixed.. remove the power cable and make sure you have not installed the battery ...then press and hold the power button for 30 sec.. then check at the bottom of the laptop if you have access to memory card if so try to open the back cover and reset the memory card and check.
-issue not fixed.. if you have access to the wifi card try and reset the wifi card and check
-if the memory card and wifi card is inaccessible then you will need to visit service center or call support
SOURCE: Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
SOURCE: My Sony VAIO's wireless switch doesnt wanna
Try to go to another place where there is free WIFI like Starbucks or similar place.
If the computer can connect there, the the problem is with the WEP KEY on your modem/router. You need to update this key on your computer's wireless connections.
We need to know what operating systems do you have and what kind of modem/router do you have to help you more.
SOURCE: power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
SOURCE: Sony VAIO Laptop won't turn on. The power lights
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
SOURCE: power socket is loose
you can call sony so they can send you an onsite tech to repair the dc in port. i think its a known issue for that series of vaio
