Question about Ingersoll Rand SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow
Capacities and pressures of Ingersol Rand Air compressors
I) Model No. ML 150
ii) Model No. MH 15
  • 374 Answers
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
Posted on May 08, 2010
SOURCE:
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
First stage psv lifting on a model 3000 Ingersol Rand Air Compressor. Cylinder on the left looking at the fly wheel. Not the top dead centre cylinder.
do you mean the safety release valve ,if its blowing off at a lower pressure it needs dismantling and cleaning the seats
Jul 05, 2010 | Air Tools & Compressors
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Hello, my name is Matt and I'm on my second gas operated T30 and the Kohler engine is about to go on this one too. I'm considering mounting the 2475 pump under my truck and running it off of a PTO....
Ingersol Rand compressors are driven by a variety of motors and gas engines. They set the rpm of the pump based on the required cfm /psi output required by the customer and power source. Your compressor has aprox 12- 15 hp gas engine that develops full power at about 3600 rpm of the engine. The pump will most likely be turning about 1000 rpm. Easy to check, just mark both pulleys and count the number of turns of the engine pulley compared to the pump. Pump specifications can be found at www.grainger.com. You will find that most ingersol pumps turn from 650-1200 rpm for max output. You will max pump life if you are able to keep rpms low (600 - 1000 turns). The pump will not lubricate properly if you turn too fast. The compressor needs between 5 and 15 hp depending on the cut-out pressure. Full hp is required as the pump neers 175psi. Good luck with your project.
Mar 27, 2010 | Ingersoll Rand - Rand Type - 30...
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Mar 15, 2010 | Ingersoll Rand - Rand Type - 30...
Ingersol rand p185wir blowing compresor oil out air inlet
expect some oil in the air. I think you have too much oil in your machine OR your rings are worn.
Dec 19, 2009 | Ingersoll Rand Air Compressor Maintenance...
Ingersol rand model SS3-E runs but does not build any air pressure. Air just blows out the intake filter.
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Nov 26, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Ingersol rand model 3000, serial no 9835350,size 5.5"&5.5"&4"x4",would like to know pumping capacity per/min
If the motor is a 20 horsepower it is pumping app. 80 cubic feet per minute . Here's a good rule of thumb 4 cfm per horse power.
Aug 05, 2009 | Air Tools & Compressors
Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
May 18, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersoll Rand  SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow  Logo
433 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
