Where to charge ac
Most charge it threw the low side ac line, there is 2 high side and low the low is the bigger fitting of the two, and should be capped follow the ac lines you will find it. However I really suggest you have it done with a AC machine by a certified tech. There is moisture in the system, what refrigerent that is in there should be recycled then a vacum to get it out, it also takes some ofthe old oil out and new put back in usually best mixed with uv dye to detect a leak later. Good luck
