Some computers will not acknowledge your flash cards. Depending on your flash card, your printer & computer to make sure they are compatible. Try opening your computer Icon to see if card is accepted. then click in your card to see if any file are in. You may have to load your printer software again..
If you refilled the ink cartridges, this can happen. Kodak uses pigment based inks, the others use dye based inks. Also, make sure your printer is set for normal photo printing, rather than special effects.
The first thing I would do is run a calibration utility, sometimes the printer doesn't know it is using too much (or the wrong) ink.
If calibrating the printer doesn't seem to work I would remove the ink\toner cartages and clean the pads and contacts of the printer to ensure that no green residue is causing your tint problem. Rubbing alcohol does the trick nicely. (if you don't have any on hand, nail polish remover works as well.)
if your prints are coming out with blue green tint, more than likely, the magenta (pink) is missing from your calibration page. Print out a calibration sheet, you should have black, yellow, blue, and magenta. If one of these colors is missing, your printhead is clogged. You need a new one. Call Kodak Tech Support.
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
