No power on N1996 argon motherboard. CPU and case fans turn on then go back off. The switch on the front is yellow then blue. I have tried a new power supply. Is there any way to troubleshoot motherboard without replacing it?
If it's switching its self off after about 10 second then Your CPU Chip is not right some how it could be / damaged / the wrong socket type for the board as alot of CPU's are very simmler / The CPU's (4 pin) power supply is not connected or the CPU hasent gone in to the socket properly when this happens it will power up but will send no power to the monitor, or somtimes set off an alarm that sounds like a sciron going off.
*********** board has been faulty.So you can repaired it from service center.
