Question about Sylvania DVR90VE DVD Recorder/VCR
DVR90VE DVD Recorder / VCR Combo: error E 4 54037380; will not format...nor load dvd...
Error E 4 54037380; will not format...nor load dvd-rw
    Guru:
  • 125 Answers
It seems like this device only supports DVD-RW 1x-2x try using these speed ratings!
Good luck Bruce
Posted on May 05, 2010
SOURCE:
I am trying to record from cable tv to dvd and also dub a vcr tape to dvd. i've tried both dvd -r and +r. do i need to format these disks first, also when done do i need to finalize and or make compatible....
DVD-R and DVD+RW and +R are automatically formatted. DVD-WR can be formatted in VR or Video mode Finalization is necessary for -rw and dvd-r, but only recommended for dvd+rw and dvd+r
Apr 30, 2010 | Toshiba D-VR600
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
I cannot format either dvd-r or rws with this machine.
try a single disk, but make sure format is not (-r or -rw; but +r or+rw )negative is mostly for computers, and positive is mostly for dvds and such; should find single at walgreens or wal-mart.
Mar 30, 2009 | Cyberhome DVD Recorder - DVR1600
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Disc error 1300
Had the same problem after purchasing DVD+RW discs. Exchanged for DVD-RW discs and it worked. I guess they are formatted differently.
Jul 14, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
I cannot format DVD-RW
I had to download the latest firmware (rev. VS0M) for Lite-On DVDRW SOHW-832S. This fixed the problem.
Jun 21, 2008 | Roxio Easy Media Creator 7
Disc Error
Try to clean the read laser and the laser pickup, by using a DVD cleaning disk. If this does not work you may have a misaligned laser or pickup.
That may sound like a canned response and it is, however it is a good start. I would also check the format of the video on the DVD-RW, and make sure the DVD player is set to display that format.  Also might I suggest that you try the documented Disk loading instructions. I know that sounds stupid, but I was working on a customers DVD player one day and I downloaded the manual, and I was shocked to find out that I was not following the recommended loading procedure, once I did that all of the disks worked (stupid? yes, but that's how things are now).
As I said try to clean the pick-up and laser, check the format of the DVDs, and then follow the recommended loading instructions.
I hope this helps
Thank you,
Shuttle83
Apr 23, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Oct 27, 2007 | Sylvania DVR90VE DVD Recorder/VCR
Sylvania DVR90VE DVD Recorder/VCR Logo
457 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
