Patton Electronics SN4114/JS/EUI Router Logo
Posted on Feb 07, 2018
No CallerId in Patton 4114 !
I've got 3Cx with softphone and SIP phone. I can call and receive phone number.
But when people calling me I don't receive their phone Number on my patton 4114 ???
Line is RTC on FX0 and I obtain 'n/a' inside the field adress where normally there is phone number of caller !!!
2 Related Answers
A
Anonymous
  • Posted on Jun 09, 2008
SOURCE: Patton ceiling heater Model# 2433
x48987
Anonymous
  • 4736 Answers
  • Posted on Feb 16, 2011
SOURCE: I'm wondering if my Patton
Please see the two previous answers to your question.
3answers
Cannot get my softphone to engage my headset.
You probably need to check your audio controls in your computer's control panel to make your headset the default audio device and also make sure your softphone control panel is set the same way.
Good luck from Headsets Direct!
Usb phone issue with Twinkle (SIP softphone connecting to Asterisk) on Ubuntu linux. This used to work but now I get the following error: Cannot access the speaker (ALSA: plughw:1,0). Cannot access...
The softphone does not detect audio hardware.Depending on the softphone you may need to choose in settings the hardware device for input/output, ensure you have done so.
If that does not work, check speakers and mic installation in Ubuntu.
3answers
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
2answers
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
7helpful
2answers
I want to make a softphone so plz give me the whole source code of softphone in php, vb.net, asp.net2.0 (any) languages.
You can find what you need here: http://www.filebuzz.com/findsoftware/Free_Source_Code_Soft_Phone/1.html
Now, admittedly, this was an easy search. I'm sure there are others, but I checked the DLs on this site, and they seem to be working fine - and without any bugs attached.
1helpful
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
2answers
Softphone will not dial out
canceled my softphone and will replace it
2answers
Voip841
Yes, If your phone supports SIP then you should be able to program any service provider. On the other hand if this is a Skype only phone then you will not be able to use it with any other service besides Skype because they use a non-standard protocol.
I tried looking up your phone and the closest I came was :
http://www.amazon.com/Philips-VOIP8411B-37-Phone-System/dp/tech-data/B000ND75FW/ref=de_a_smtd
This says in the Tech Specs that it is voip client and softphone compatible (whatever that means). It doesnt say it is SIP compatible. So look up the user manual and if it says that your phone is SIP compatible then you should be able to program any VOIP service provider (90% of them are SIP based) but if all the manual mentions is Skype and nothing else, then you might be out of luck.
Hope that helps!
-AM
Top Patton Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Patton Computer and Internet Expert? Answer questions, earn points and help others
