I just installed a spy 5000m and everything works, except for the remote start. I activate the remote start and all it does is crank and cut off.... it does this three times....did i install something wrong? by the way, this installed on a 2004 Honda civic... plz help!
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
Spy 5000m, mod, 2004 Cbr1000rr.
Instead of remote start ( I'll never need) I hooked pink wire to 12v red wire going to alarm,
brown wire to LED lights I mounted around bike.
Push the remote start on fob twice, lights up perimeter LED's, to turn off, push disarm button twice, lights off. Then push dis-arm one more time, your turn signal lights will flash twice.
Note:
While your lights are on, your alarm will not sound or activate until you turn off perimeter lights, then re-arm your alarm.
Auto re-arming trick:
if bike keeps resetting your alarm, after you dis-arm, activate your shock sensor( I knock on my seat three times), bike then stops re- arming,
otherwise alarm thinks it was an accidental dis-arm, and re-arms for you.
I had the same problem. There may be an anti-hijack feature in your ignition switch that you need to bypass - call the place where you got the alarm for details.
Mine was when you use the key to turn on the ignition, 3 connections were made. When I hit the remote start, only 2 were made - so I had to install another relay to make this 3rd connection when the remote start was used.
