Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run again. I have checked the air pressure in the air tank and it's ok. The voltage seems ok and it's not hot or running out of water. The water is supplied from a water holding tank and it has plenty of water when the problem occurs. This is a new pump so this is not an age-related issue. The seller, "fresh water systems" says to call Grundfos but I can't find an 800 number (or any phone number) for technical support. The Grundfos web site says contact your distributor for support. "fresh water systems" says contact Grundfos for support. Any ideas?
  • 3 more comments
  • Dean Larson
    Dean Larson Mar 09, 2014
    Grunfos Pumps
  • Dean Larson
    Dean Larson Mar 10, 2014
    Gundfos Pumps
  • Dean Larson
    Add a CommentWest 118th Terrace
  • Dean Larson
    Add a Comment Grundfos Pumps
  • Dean Larson
    Grundfos Pumps, 17100 West 118th Terrace, Olathe, Kansas 66061, 913-227-3400
    President:
  • 1,902 Answers
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
Posted on May 04, 2010
  • billnagle54 Oct 07, 2010
    did you get a better answer than this? Like 'where is the air coming from?" so you can do something about it. This is my problem as well and it may be because of air sucking into the suction (low pressure side) line from the tank - faulty couplings? low water in tank or non return valve not sealing? Any suggestions?
SOURCE:
Just installed a MQ 3 -35 in my home in order to improve low city supplied water pressure (35psi). Now my home pressure is at 75 to 80 psi, too high. How can I regulate the pressure down to 55-60 ps
proper way is to install a water pressure regulator and due to potability reasons it needs to be brass ,bronze, stainless steel, or CPVC plastic , (no steel or cast metal) of course the less high tech way is to plumb a valve from pump outlet back to its inlet and adjust valve to max pressure setting you want at max demand , I don't recommend this method as it wont be able to give you a constant pressure regardless of demand as the first method will , Note: some water regulators are a "relieving" type and require special install methods and maybe three lines to it
Aug 16, 2015 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Grundfos MQ 35 won't run
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Jan 24, 2014 | Plumbing
Grundfos MQ 35
Check the capacitor or the centrifugal switch.
Aug 26, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Problem with mq pump
MAKE SURE THE PUMP IS WIRED FOR 120/220. THE WIRE GAUGE
SHOULD BE #12 OR #10 IF 100 FEET.
Brand new Wel Bilt 1 HP shallow well pump, shuts off after running for 5 to 10 min !!! Help ! JGP12001CHT (Northern Industrial Shallow Well Pump. Installed to pump creek water for yard, runs at 30 PSI on...
It sounds to me like you have a defective thermal switch that is shutting power off as if motor is overheating.Unless you are exceding the head or flow ratings on the pump I would recommend you return it for replacement.Thank you.
Jul 13, 2011 | Plumbing
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
My Grundfos MQ pump intermittantly continues to run when there is no demand, especially after drawing off a small quantity of water. It then overheats. The plumber has replaced the pressure tank but the...
I have the same problem and have found that the inlet check valve has a broken shaft in the center of device. It is a multi-piece plastic unit and it looks as if it is not quite seating and therefore the internal pressure leaks slowly back into my low pressure suction line. The pump will start and the pressure will build then shut off for about 30 minutes then cycle again. I am going to replace the check valve.
Mar 06, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
996 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
