I have error E354 on copier IR2016 what can i do to get rid of it?
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Have error E354 on copier IR2016 what can i do to get rid of it?
Error e354 code appear when you replace PCB controller board.
Please note. Before replace your old PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
i have a 2 main bourd win i changed it i get this problem
System Error E354"
