SOURCE: Wiring problem
There should be a diageram under the cover that covers the wires,
Or note the two terminals marked L1 & L2. These are for the 2 power source wires from the circuit breakers. The ground is a seperate terminal.
You should not be servicing this type of equipment if you do not know the answer to your question,
Good Luck and make sure this motor is GROUNDED
SOURCE: Looking for a wiring diagram for an A.O. Smith
Thank you for posting your question here on Fixya.com.
That actually appears to be part of the serial number, not the part number at the end of your post. What are you trying to accomplish? With a description of your terminal board and the current wire arrangement I should be able to tell you what you need to know. Another option would be to contact us through our site at www.arrowmotor.net and send a picture of the board.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: I want to reverse rotation
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
SOURCE: Need wiring diagram for AO Smith Motor. Model #
Remove the rear cover and take a look. Unless this is a very old motor, there will be an indicator on the tab that will tell you the information you seek.
Normally ... let me say again, normally, a larger motor will come default 220 while a fractional hp motor will be 110.
To be double sure, take your motor to your Professional Pool shop and ask them to have a look.
