Acer Aspire 5100 Notebook Logo
Anurag Jain Posted on Mar 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer Aspire 4720 RHEL4 Installation
I have Acer Aspire 4720 with Vista Basic Pre Installed.
I have installed Linux on other Partition by boot linux all-generic-ide noapic nolapic
as dual boot.
everything gone fine finally when i rebooted Linux after successfull installation of linux.
errors : are followings screenshots
Booting Command- List
root (hd0,4)
filesystem type is ext2fs, partition type 0x83
kernel /vmlinuz-2.6.9-5.Elsmp ro root=LEBEL=/ rhgb quiet
[Linux-bzimage, setup=0x1400, size=0x15492c]
initrd /initrd-2.6.9-5.Elsmp. img
[Linux-initrd @ 0x37f91000, 0x5ef39 bytes]
Uncompressing Linux ... Ok, booting the kernel.
PCI : Failed to Allocate mem resource #0:1000@38000000 for 0000:04:00.0
PCI : Failed to allocate mem resource #0:10000@38000000 for 0000:05:00.0
Red Hat Version 4.1.18 starting
mkrootdev: label / not found
mount: error 2 mounting ext3
mount: error 2 mounting none
switchroot: mount failed: 22
umount /initrd/dev failed: 2
Kernel panic - not syncing: attempted to kill init!
My Windows Vista is working fine
  • 1 more comment
  • Anurag Jain
    Anurag Jain Mar 26, 2008
    I think Fixya dont have linux experts....
  • Anurag Jain
    Anurag Jain Mar 27, 2008
    I already selected Linux Boot Loader while installed. and other thing Linux partion should have more than windows partions space. is not possible because i have following partions
    1. ESIA Recovery partions 12 GB
    2. 70 GB 1st Active partion for Vista
    3. 35 GB i am using for DATA for Vista
    I have total 160 GB space on HDD so rest i am using for linux
    and i thing it is sufficient. please clear if any login behind it.
  • Anonymous May 11, 2010
    I'm not familiar with Linux . i have a desktop computer. it is saying. i can't reboot unless i switch of the main button. Kernel panic - not syncing: Attempted to kill init!
    What to do????
    Adele
EKASYS IT SERVICES
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 215 Answers
  • Posted on Mar 26, 2008
EKASYS IT SERVICES
Expert
Level 2:
Mentor:
Answers
215
Questions
0
Helped
61511
Points
481
Again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
  • EKASYS IT SERVICES
    EKASYS IT SERVICES Mar 27, 2008
    that's what the problem using partition magic do free space in 70 gb free 30 gb free space and try installing
2answers
What is the procces of operating system instal
there are a lot of ways:
1. Install through USB Device.
2. Install through a DVD.
It would also depend on the type of Operating System: Linux or Windows.
It is relatively easy to install Windows OS than Linux though it is easy to install Linux is easier when installed inside windows.
For windows installation:
1.Insert windows DVD or USB and boot through the device inserted.
2.After the language selection, you will be directed to select the partition in which the windows will be installed.
3. Select the partition and click install.
4. the software will be installed over time.
for Linux installation:
it will depend on the type of linux. it is best to refer the particular linux's free documentation to better understand the installation process
2answers
I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
make the windows partition the "Primary" or "Boot" partition.
When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
The next concern is which operating system will boot by default,Windows or Linux.
I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
I have Acer aspire 5742 model. It has operating system of Linpus I want to remove it and install windows 7 and Linux os. Please give instructions to do that chirani
You don't have to do anything to remove it actually. If you just format the disk it will be removed (for ever though) so just install the right on it don't even have to boot in Linpus.
Making your laptop Dual boot(that is the term for having two operating systems on a computer) with windows and Linux is a little tricky though.
Basically the whole problem is that windows will wipe your linux if you are not careful and will wipe your boot partition for sure (Windows 7 might not - haven't tried it).
So All you have to do is install Windows. While partitining the disk just take enough space for it and leave enough for the windows - you can wipe the whole disk if you want to. The Linux will need from 4 - 12+ GB of installation space (maybe less if it's live cd and you won't keep files there).
After you have installed your Windows. Just install your favorite Linux distribution in the space left.
If you have any other questions mainly to the Linux installation, I'll be pleased to help you.
1helpful
Linux to xp
absolutely! all you need is your windows install CD and the installation will prompt you to select a partition, select your linux partition, delete it and start a new with XP. it's very easy.
Back to get the original vista version
Well, with any amount of luck, when you installed xp you didn't erase the recovery partition. Just boot into the recovery partition. Some laptops will let you have that option on a regular boot.
Of course, if you have the vista cd, just boot with that. You can download a free vista recovery cd here:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
If that doesn't work, try to download easyBCD and hope that your vista partition shows up in xp:
http://neosmart.net/dl.php?id=1
Want to load xp and linux
make a partition (fat) in linux using cfdisk & vfat commands then boot from ur winxp cd and install it in this partition
1helpful
2answers
WiFi driver for Acer Laptop 4720 for Linux (Fedora version 8) free download
Try this link and see if it helps you locate the driver you need for linux. These are the Broadcom drivers, http://zh-tw.broadcom.com/support/ethernet_nic/netlink.php
2answers
I need step by instruction to instal linux with vista
To solve this problem you have to make a partition form the outside of windows
1 - delete the partition you made in vista
2- download from the internet an Fdisk bootable floppy OR use Puppy linux live cd and run gpart from menu > setup > gpart
3- folloe the intructions on the fdisk program and then install linux
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Dual Booting
possibly by first creating a new partition large enough for Linux OS, but does not solve your problem...try getting a VISTA startup disc from another pc (floppies if you have the drive) and startup from these.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
