Brother MFC-6890CDW Printer Logo
Posted on May 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing The printer will not feed paper though and print, but it will printer if manualy feed the paper???? Thanks for your time.
Anonymous
Level 2:
  • Expert 292 Answers
  • Posted on May 04, 2010
Anonymous
Expert
Level 2:
Answers
292
Questions
Helped
86162
Points
699
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
How do I change the paper sixe? When I feed the paper through the feeder it prints halfway down the paper even though I have it set on 5x7 for printer and paper size. I have a richoh2100 laser printer
HI there before print go in printer preferences and select page setup. After that that set the page and give a look on print preview. If you happy with setting then save and Apply. Now print and let me know the result. Thanks.
1helpful
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
2answers
1helpful
I have an old Wipro LX 540 dot matrix printer and though it always worked good so far but recently it is causing a strange problem. When I send any document to print, only a line ro few get printed and...
please check paper sensor which one coming down the paper roller clean the sensor it will work .. this problem coming because paper is not sensing in middle of printing ... and check the paper feeding properly or what ....
1helpful
Not grabing paper to print Seem as though the roller feed is not
This will happens when the paper feeder sensor fails. Due to this when give any print or copy it wont feeds the paper you may get the error please load the paper. For this you need to contact HP Customer Support for a service if it is under warranty.
Thanks & Regards Nandu :)
Envelopes won't feed
try to adjust manualy the paper adjustment at the bottom
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
1helpful
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
3answers
Hi there i need some help, I need to find out why my paper will not go into the feeder area of the printer. I have tried different ways and it just won't feed even though the rollers roll. Thanks call if...
This printer comes with major paper feeding problems, even on the FAQ for this printer on HP's website paper feed problem is the number 1 FAQ. It either misfeeds or won't feed paper. An average example is if you try to print a 6 page report, it will missfeed about 10 sheets to print 6, and you will spend a lot of time pushing the paper feed button.
Following the guidlines in HP's faq about this does nothing to improve the situation. HP basically denies any problem with the printer and wants the consumer to pay to ship and have the printer fixed, even if it is new. They will give you phone calls and emails with a lot of PR babble, but do nothing. Stay away from this piece of junk, HP is aware there are major paper feed problems, does nothing about them, and doesn't take it off the market.
Norman Weimar
Norman Weimar
k24674
