I have problems with booths of my toilet seat.
When sitting down it move's & every think is tide .
My question is WHY ?????????????? It is also very unsafe, you feel like you will fall of the seat.
Try checking plumbing supply houses instead of home improvement stores. Im not sure where you are located. Here in MO. I use Harry Cooper Supply or Riback Supply or Southern Materials. A good supply house should be able to help you find what you are looking for. Hope this helps.
SOURCE: Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
SOURCE: have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
