Sony Xplod Amplifier XM-SD51X - Class D 1100W Mono Amplifier Car Audio Amplifier Logo
Posted on May 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have this amp...the sony xplod xm-sd51x class d 1100 w monoblock...it doesn't say its bridgeable but I would like to know if it would hurt it if I did bridge it.
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sony Master 2,226 Answers
  • Posted on May 04, 2010
kenw392
Sony Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
473844
Points
4986
Monoblock amps are NOT bridgiable. there is a good chance you will burn up the amp if you try it.
How much should I pay for a used one?
For a class D amp from Sony at 1100W peak, I wouldn't pay more than $75 for a used one.
1helpful
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
My audiopipe 30001d amp come on but the protector light come on and it want work
Try unplugging everything exept the 12v, ground, and remote. See if you have the same problem. If no, you probably have a shorted speaker. If yes, an internal amp problem. [email protected]
When my amp comes on the green light turns red after a few seconds and sometimes it just fades out compleatly. but all my conections are good. what should i do?
disconnect your speaker wires and see if it still does it. if it doesn't you either have a shorted speaker wire or bad speaker. if it still does, the amp is bad.
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Amp not putting out any sound
Check you pre amp RCAs and make sure they are holding a voltage...this is where the Amp takes that signal and amplifies it...without this connection the amp will not produce any power.
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
