Philips Magnavox 42MF521D/37 Television Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV went out.
TV had a smell and then went out. When we turn it on it flashes green on the power button. What can be wrong? It is a Philips Magnavox 42MF521D/37 Please help.
Thanks
CoppellTVRepair.com
Level 3:
  • Philips Master 778 Answers
  • Posted on May 20, 2010
CoppellTVRepair.com
Philips Master
Level 3:
Answers
778
Questions
0
Helped
396568
Points
1847
This is neither the power supply.
Replacing a transistor will not solve the problem either.
The smoke comes - most of the time - from a Y sustain buffer board; Betleano above tells you one small thing that's needed to be done on the Y sustain board, but it is MOST CERTAINLY not the only thing that will need to be done.
At the very least you will need to replace a buffer board or you risk burning another transistor and possibly more.
There are two sane approaches to this: have the Y sustain board repaired and replace the two buffers; or replace all three (the Y sustain board and the two buffers) together.
While theoretically possible that your problem might be elsewhere, 99% of all 42'' plasma Magnavoxes that come to our shop have that problem.
www.coppelltvrepair.com
TEXAS TV PARTS
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on May 18, 2010
 TEXAS TV PARTS
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
6796
Points
56
replace a transistor in the power supply and a diode that has shorted out near this transistor,this transistor is located near other in the same heat sink,and check the tall caps for swollen top,thanks everyone!!!
Chi Chu
Level 3:
  • Philips Master 8,457 Answers
  • Posted on May 02, 2010
Chi Chu
Philips Master
Level 3:
Answers
8457
Questions
0
Helped
2822955
Points
26282
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
The tv will not turn on either by pressing the power button on the tv or by the remote. What I do see is a green intermittant flash on the power button. whats wrong?
Hello
Your Magnavox TVs system video jungle Ic has damaged. No horizontal or vertical sweep is there and the IC stated above has gone shorted. Replacing that is is the only remedy. But before replacing it, a through circuit check is necessary. If you are fully aware in electronics and have good soldering knoledge and experience, inform me through Fixya. I'll assist you. Remember, it is not an easy thing as you thinks. OK.
When I press the power button on the front of the tv it just flashes green. Thats all it does flash green no sound no picture nothing. PLEASE HELP
Power supply board is dead.Replaced this power supply board will solved ur power problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2answers
Tv went off with strange noise and we smelled something burning, but no flame. TV will not turn on. No light, nothing. IS TV fixable or should we replace? It is a magnavox tv that is at least twelve years...
Hi
as you said.. you have defective horizontal output transistor! and or the power section, please check the power regulator first. this is repairable..
Thanks!
Tv Philips Magnavox won't turn on
Its Broken And Now Dangerous i would not even try getting it fix. That burnt smell is never a good sign
Power problems with philips magnavox 25TR19C1
aparece codigos en la pantalla MSD luego 55 sy
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
