Question about Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair
PRONTO M51 FEELS LIKE I AM DRIVING OVER ROUGH ROAD AFTER REPLACING THE BATTERIES. WHY?
    New Friend:
  • 68 Answers
If you chair was down for a long time before getting new batteries the tires could have developed flat spots on them. Also could have brush problems in the motors that make the motors run jerky from sitting too long.
Posted on May 01, 2011
SOURCE:
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
How many batteries does a pronto electric wheelchair use
The Pronto M51 takes two batteries. It takes what is called a U1 size battery.
May 26, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto M51 feels forced when driving it.
The squealing noise is probably a bearing either in one of the four smaller tires called casters. The problem will not likely cause a break down right away but should be checked by someone mechanically inclined or trained in power wheelchairs. I don't know what you mean by the chair being "forced". Need more info.
May have something to do with batteries.
If the chair is driving slower and batteries are new their is a recall for that joystick from Invacare. Invacare is replacing joysticks for free.
Dec 15, 2013 | Invacare Pronto M51 Power Wheelchair
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
Where do you find the best value for Pronto M51 Gel Batteries
do you want cheap or good quality. you get what you pay for. MK gel batteries are by far the most superior but pricy, INTERSTATE is good middle of the road, i like their glass mat type for value V price. others are a **** shoot cause they are low price, you are paying for lead content, priced metals these days?
Nov 09, 2012 | Health & Beauty
I have added new batteries to my pronto m51 when i went to charge i am getting a flashing green i think it should be yellow?
recheck your polarity on the batteries carefully, i've done it for 15 years and the factory makes it complex sometime i connect backwards initially
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Battery won't charge
Most likely you need new batteries. On the M51 powerchair the batteries are located in the center under the seat. Step 1 - remove the seat by pulling up on the swivel handle while lifting straight up, the seat weighs about 50 lbs. After removing the seat remove the center plastic cover by liting it off.
If you have an older model M51 the batteries will each have their own cover - to replace the batteries you will see several connectors that must be unplugged. The front and rear batteries each have different connectors so keep them separate. Lift out the batteries and follow the wiring for each replace the batteries. You will need 2 U1 batteries, available at sears or your local maedical equipment supply store ( Interstate has them too) Simply reverse the removal procedure to replace the batteries making sure you follow all the connections. - good luck
Tom
Mar 20, 2009 | Invacare Pronto M51 Power Wheelchair
Open Questions:
See all Invacare Supply Group Invacare Pronto M51 Power Questions
Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair Logo
115 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
