Exercise & Fitness Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not get the seat to move out of present position?
I have a weider crossbow advantage home gym, the seat will not move from its present position. I do not have the owners manual to this equipment need help.
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on May 02, 2010
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
99050
Points
350
Here is the owners manual link for a free download. http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=15396&modelName=CROSSBOW+ADVANTAGE+BY+WEIDER&version=2&company=11&language=
This model has a screw in locating pin holding the seat in and somtimes I have the pin "freeze" . You will nee dto unscrew the pin before pulling it out. If it the knob comes off of the end of the pin then the pin is "frozen" and will need to be loosened with some penetratinfg oil and probably a pair of vise grips. Be careful not to damage the threads on the shaft where the knob goes. Good Luck!
Tim
2answers
Lost weider crossbow assembly manual
how do i set cables for my weider pro multie gym
Looking for owners manual for Weider Crossbow.
Go to www.iconservice.com click on to manual then input manufacturer then the model name and their are 12 manuals for the crossbow.
1helpful
Learning how to set up the Weider crossbow for different exercises,I have no paperwork for this machine and not sure how to use it..
Go to iconservice.com click on to manual input weider then brand name crossbow and their is 12 manuals to choose from and I found 1 YouTube video about 3.28 mins long more of promo then instructional but it give will you an idea how to use the unit.
I got a Weider Crossbow and i want to know how to install it
Go to iconfitness.com go to customer service click on to manuals Put manufacturers name and brand name you will find an owners manual for the Crossbow
Got an weider crossbow frm a friend, cnt find where to plug the pwr cord n
The power adapter should be located on the rear of the machine on the bottom about 5-6 inches from the floor.
Good Luck! Tim
I have a weider crossbow platinum
Hello there, If you go to iconservice.com they have contact information, manuals and just about any other information you may require for your Crossbow.
Fyi the first thing I would check is the power supply itself to be sure it is putting out the correct voltage.
Good Luck! Tim
1helpful
Weider multistation gym. Need manual.
Hi there, Well first thing you need to do is get a manual. Weider manuals are available on iconservice.com. To obtain the manual you will need the model number. This should be located under one of the seats. (usually the bench press seat) once you find the model number go to the web site listed above and go to the manuals section and input the model number. The manual is a free downlable and printable pdf file.
The manual will contain the cable routing info.
Good Luck! Tim
I need the instruction booklet also
I bought a golds gym gr 7000 from some one and not sure the wide range of exercises I can do on it, "no booklet"
2answers
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
6helpful
Have weider cross bow advantage home gym. need instruction manual
Here is a link the the manual in PDF for you.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/weider/manuals.d2w/report?man=&name=WESY39241&lan=
Sorry but I could not locate a source for the wall chart. The 2 places that used to sell them now say they are not available. Hope this helps!
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
