If this is a Maytag Epic, you are referring to the drain pump reservoir. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Make sure you also check the hose that runs from the bottom of the wash tub to the inlet side of the pump. Small articles of clothing can become lodged here. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If the link does not work for you, copy and paste to your web browser. Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
