Faberware FCP412 Coffee Maker Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace top - Faberware FCP412 Coffee Maker
Ronald Callahan
Level 2:
Scholar:
  • Expert 176 Answers
  • Posted on Jul 26, 2010
Ronald Callahan
Expert
Level 2:
Scholar:
Answers
176
Questions
0
Helped
40140
Points
219
Email [email protected]. He has ALL the parts. Ron
How to lift up glass top for heating element replacement.
Most of these units have a few screws underneath the top at the front lip where the top of the door closes. Remove the screws and you should be able to lift the top up. Most of them also have a metal bar you pull down or up depending on the make and model on the side to hold the top up once you open it
2answers
Goodman ckl36-1e
No you can just replaced the top .When blade hit the side of the unit make sure it didn't burst any piping
Remove and replace starter
Replacing starter is not a difficult job.The vehicle needs to be lifted up on jack stands.The starter needs to be accessed from under the car. --------- You need to remove the air filter housing and intake, and the battery and tray if you want to make it easy on yourself. Remove those first, then remove the top starter bolt before you go under the car.
Accessing the top starter bolt,sometimes takes time. The top bolt comes from the transmission side on top.
Click this link below to see diagram showing location of top bolt:--- http://technoanswers.blogspot.com/2011/10/how-to-replace-starter-on-2000-mazda.html --------- This will help.Thanks.Helpmech.
1helpful
Need to replace the soft top on a 2003 Honda S2000 need how to remove old top and put on new top
Here is a link to an article by a guy that did repalce his top with step by step instructions and pictures...
http://www.s2ki.com/forums/index.php?act=ST&f=1&t=448840
Replacement top available at ...
http://www.robbinsautotopco.com/homepage.html
1helpful
Remove and replace convertable top on a Chryster Sebring
albert I need to tell you this buddy you have saved some money on the top I would call a uphostry shop in your area they will pick up car and repalce the top for you and the window needs to be seemed in there for safety reasons call one up I hate to tell you that but. Your better off having a specailty company do this if you need anything go to collsionrepairadvice.com
Broken top of radiator
You can buy the top only and have it replaced, yet the shop time/labor would be more than its replacement of a new one.
Estate top loading washer needs a lid switch replacement
I found one one NEW on ebay for 6.50 + shipping, total 12.49. Other parts places had them for a lot more. It wasn't too hard to install.
1997 bmw 328 convertible top deck lid strut replacement
NEED YOUR EMAIL TO SEND SOME IMAGES.
HERE ARE THE STEPS TO FOLLOW.
REPLACING LEFT AND RIGHT GAS STRUTS FOR SOFT TOP COMPARTMENT COVER :
  • Remove soft top compartment cover.
  • Lift soft top out of soft top compartment.
  • Lift gas strut out downwards, insert in available bore and lower the linkages.
  • Remove tab washer, raise gas strut upwards and lift out.
HOPE THIS HELPS
Top Faberware Coffee Makers & Espresso Machines Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
john h
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
