MSI Wind U100-030US Laptop Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i do recovery for my msi ?
When i turn on my computer it jumps to a screen with 5 options: safe mode, sademode with networking, safe mode with command prompt, last known good configuration, and start windows normally. None of them seem to be working, even when i pick safe mode. Every time i pick one, it jumps bak to this screen after the windows loading screen. My question here is how do i fix it ? n If i cant fix it, how do i do recovery in here ?
  • Anonymous Mar 21, 2014
    I'm in the tropics since 2 weeks so maybe it is due to heat and humidity? However when the laptop was new I spent six months in the tropics with no problems with the computer.
    any idea how to solve the problems with screen and s-bar?
    Thank you
naddoura
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 56 Answers
  • Posted on May 02, 2010
naddoura
Expert
Level 2:
New Friend:
Cheetah:
Answers
56
Questions
Helped
12415
Points
161
Just insert the cd and boot the computer from it and then choose fix problems
  • dbpj101 Jul 09, 2010
    The U100 does not have a CD drive. Make a bootable USB drive of XP or Ubuntu, recover files and then use an F3 Hotkey system recovery back to the default factory settings.
Hi. how can i enter in safe mode on an asus k50ij with windows 10 ?
Here you go:
Start your PC in safe mode in Windows 10
  • ?Email
  • Hide all
    From Settings
    1. Press Windows logo key Windows logo key + I on your keyboard to open Settings. If that doesn't work, select the Start button in the lower-left corner of your screen, then select Settings.
    2. Select Update & security > Recovery.
    3. Under Advanced startup, select Restart now.
    4. After your PC restarts to the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
    5. After your PC restarts, you'll see a list of options. Select 4 or F4 to start your PC in Safe Mode. Or if you'll need to use the Internet, select 5 or F5 for Safe Mode with Networking.
    From the sign-in screen
    1. Restart your PC. When you get to the sign-in screen, hold the Shift key down while you select Power > Restart.
    2. After your PC restarts to the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
    3. After your PC restarts, you'll see a list of options. Select 4 or F4 to start your PC in Safe Mode. Or if you'll need to use the Internet, select 5 or F5 for Safe Mode with Networking.
tip
Lost Windows 7 Password, How to Get in Your Password Protected PC in Safe Mode?
Lost Windows 7 password, what will you do to get in your password protected computer? In fact, there are lots of ways for you to regain access to the locked computer? In addition to use a password reset disk to reset Windows 7 password, you can still log on your PC in safe mode to change the lost Windows 7 password. It is very simple. Just three steps. You could follow the below guide.
Step 1: Enter safe mode in Windows 7 operating system
1. Start or restart your Windows 7 machine.
2. Press the F8 key to enter Advanced Boot Options just before the Windows 7 loading screen appears.
3. Use arrows to choose Safe Mode when you can see the Advanced Boot Options screen.
4. Press Enter and wait for Windows 7 files to load.
5. Log on with an administrator account when you can see the log on screen.
Step 2: Change lost Windows 7 password
Now you are logged into Windows 7 in safe mode. You diagnose and solve some serious problems under it, especially when starting Windows normally is impossible. To reset Windows 7 password, just do as follows:
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3. Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Note: you can also go to Local Users and Groups screen by right-clicking Computer to select Manage on desktop.
Step 3: Log on your computer with the new password
You have successfully perform Windows 7 password reset. Now you can easily access to your compute with the new password. Please note that you must log on with an account that has administrator permissions.
More information:
When you are presented with Advanced Boot Options screen, there are 3 variations of Windows 7 Safe Mode.
Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Safe Mode with Networking - This option loads the same processes as Safe Mode but also includes those that allow the networking functions in Windows 7 to work. You should choose this option if you think you may need to access the Internet or your local network while troubleshooting in Safe Mode.
Safe Mode with Command Prompt - This version of Safe Mode also loads a minimum set of processes but will allow immediate access to the Command Prompt. This is a valuable option if more advanced troubleshooting is necessary.
Actually, the 3 options are available for you. I only take Safe Mode as an example. But if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to change the lost Windows 7 password.
If you cannot log on Windows with an account that has administrator permissions, you will be not able to enter Windows safe mode. In that case, I'm afraid you'll need third party software Windows Login Recovery to help to bypass your lost Windows 7 password and get back in your protected computer. Windows Login Recovery allows you to reset lost Windows password with a bootable CD/DVD or USB flash drive. It takes you take less than 5 minutes.
on Oct 25, 2010 • Computers & Internet
Startup Repair cannot repair this computer automatically
Try booting into the Safe Mode and check if the issue persists.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words Safe Mode appear in the corners of your monitor to identify which Windows mode you're using.
1. Restart your computer. Click the Start button, click the arrow next to the Shut Down button, and then click Restart.
2. Do one of the following:
· If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
· If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter.
4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
To know more information on how to boot into Safe mode visit the following link:
Start your computer in safe mode
http://windows.microsoft.com/en-us/windows7/Start-your-computer-in-safe-mode
Method 2: Also scan the Computer for error using chkdsk command in the Command Prompt from the System Recovery Options Menu.
To open the System Recovery Options menu on your computer
1.Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
2.Do one of the following:
•If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
•If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3.On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4.Select a keyboard layout, and then click Next.
5.On the System Recovery Options menu, click a tool(Command Prompt) to open it.
6. At the Command Prompt, type: chkdsk /r . Press Enter.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
My Toshiba laptop won't start. When I turn it on a command line itnerface appears saying that Windows won't start sucessfully and it may be due to a recent hardware or software change. It gives me 5...
Go to the safe mode option then once there go to start-run-then type in MSCONFIG then go to system recovery then go to recovery for an earlier time. This will reset your Windows to an earlier time you may be able to salvage it without having to re-install the operating system. F8 also will bring you to "Safe Mode" if not do it through the Dos command screen. If this does not work then you might consider re-installing Windows again. John
4helpful
3answers
My son as put a password on his u100 he fogot it and now just password screen can anyone help
Boot in Safe Mode with Networking: 1. Restart your computer.
2. Once your computer starts to turn on, press F8 (or for other computers, it could be F5) repeatedly until you see the boot option.
3. Using your arrow keys, highlight Safe mode with networking then press enter.
4. Log in as the Administrator.
5. Click on yes when it prompts you that you are running in safe mode.
6. Go to Control Panel then User Accounts, reset the password for your Windows User Account.
7. Restart the computer normally.
2answers
After starting no responding, screen stay dark, only the mouse point is visible and move, but is nothong else on screen
Try using the Safe Mode option .
Instructions : Keep tapping on the F8 key on the computer as soon as you turn on the computer. Choose the option that says safe mode with networking.
Also try reinstallin the OS using the recovery partition or the Recovery cds with the computer.
2answers
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
My toshiba satellite a105-s171 will not boot up. it acts like it is starting but after the windows xp screen a blue screen flashes with white lettering but does not stay long enough to read and then the...
You need to do a recovery using the recovery console. There is an option during startup, if you are running XP or later, to press F11 for emergency recovery.
Press F11 and choose the option to recover and backup.
This will backup all files and programs currently installed on your computer.
After the recovery process finishes, you will have to go through the process of setting up your computer, like you did when you first bought it.
After you are all setup again, it is a good idea to create recovery disks under the 'Start' menu, 'Recovery' option.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
