Question edited for FULL 'make model (what it is).
Question moved to 'make model' category.
Duplicate post deleted, two posts made into one. Refresh page to see your question published.
The C340 works with MMC and SD cards. Your 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use a MMC or SD card, which top out at 2GB.
The C340 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use cards 2GB and smaller.
First, make sure you're using a supported card. The C340 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card and won't work.
If you do have a supported card, make sure the image storage location is set to Auto. In the Review mode, press the Menu button then select Image Storage (camera and memory card symbol).
The C340 uses MMC and SD cards. Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
The C340 is designed to work with SD cards. While SDHC cards such as your 4GB card will fit into the slot, they will not work. You need to use SD cards 2GB and smaller.
Wasn't the card that came with the camera 2GB or smaller? The C340 is designed to work with SD cards, 2GB and smaller. Your 4GB card is actually an SDHC card and will not work in the C340.
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
