My All-In-One is an Epson Aculaser CX11NF. If I receive a large fax job, it will sometimes only print part of the job & leave the rest in memory. What can I do to get it to print these?
By installing a Dual In-line Memory Module (DIMM), you can increase product memory up to 576 MB. You may need to add memory if you are having difficulty printing large documents
contact epson support line if you want to add memory card/module
press fax button and press menu, make sure that printng report is selected and press right button then select memory job info so that it will print the pending documents on the memory. adding a memory card module is an option so that if you are actually sending a multipage doc in which is a large file if you have a larger memory chances are if you received larger file it will print it all.
