Hotpoint HSS25GFP Side by Side Refrigerator Logo
Anonymous Posted on Mar 25, 2008
No water water not coming from door
  • jamesmullen Apr 13, 2008
    I have a hotpoint fridge model HSS25GFPHWW. The ice maker/dispenser works, but the water dispenser quit a couple of months ago. I have good water supply & pressure to the appliance. Could the controlling electronics (mother board) be "half dead"?? If so, how much are new ones??
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Mar 28, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
21808
Points
74
For a very informative videono water - 1.gif on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
the model may look different but these tips will help you narrow down the problem.
Door water dispenser not working
It may be the water line in the door is frozen. I have come across this several times. Check to see if the water is coming to the door by disconnecting the quick connector to the door behind the grill at the base of the refrigerator. If water comes out of the tube there then you will have to defrost the freezer door by leaving the door open for a coule hours.
New water filter, water coming out of door, but not coming through filter
If water is coming out of the door, then it is passing through the filter successfully. It is possible that you received a faulty filter if the door water does not seem filtered. For new filters, visit https://www.freshwatersystems.com/s-2-replacement-water-filters.aspx.
12helpful
2answers
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
1helpful
No water d from door, although ice maker works fine . i shut water off in townhouse and trun ocemaker off when we leave. when we retur, i turn water back on and ice maker works but water does not come from...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Water in door is not coming out very much intermiient
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
1helpful
Water in door suddly quite. have replaced the water filter but still notthing
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Side by Side refrigerator water does not come out. Replaced filter and still does not come out. Light, Ice and crushed out work.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water comes out here
No water going into door for dispensing or ice maker mod# MRS26LJ
I'm not sure what you damaged with heat but- Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws OR
Water coming from under door
  The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
