SOURCE: manual for nostalgics ice-cream maker
I found the Nostalgia Electrics product manuals linked on the The Helman Group, Ltd. website, http://www.helmangroup.com/ .Click nostalgia electrics, then customer service and select a product. good luck.
SOURCE: how do you make ice cream with the k-tel Quick Chill ice cream maker
K-tel International is in Winnipeg, Manitoba, Canada. I also just got the same machine with no manual. I phoned them and they are sending me one in the mail. Just go to their website; go to "contact us" and phone or email them. They were very helpful.
SOURCE: I have the krups ice cream maker 337 and cannot find my manual
Here is the manual in a PDF file on the web:
http://www.pickyourown.org/icecream/Krups%20337%20La%20Glaciere.pdf
Enjoy!!
Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
