Ecoquest Flair Air Purifier Logo
Posted on May 01, 2010
My Flair smells like it is burning and the plates are making a loud sparking sound
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
868
Points
If your machine is several yrs old, perhaps the plates need replacement; take them out check to see if they have cracks, burn holes et al; if so it or they need(s) replacement; transformer also may be dysfunctional.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 29, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
7986
Points
18
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
2answers
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
7helpful
2answers
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
1helpful
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Flair sparking
Contact [email protected]. They will be glad to help you.
WET DOG
Hi Teresa,
that is certainly not the smell the machine should produce :)
The smells, other then fresh air, might be 'trapped' in the filter. So washing the filter (top rack of the dishwasher works for the metal mesh filters) might do the trick.
Another trick you can try is to put the purifier on the floor, turn it on high mode (away mode) and put a box over it. Let it run for an hour or two and the smells should be gone.
Make sure you have fairly new plates, to make the machine more effective.
Dutch
1helpful
2answers
THE WET DOG SMELL
try soaking the grid plate in ammonia
Sparking
You got new plates they offer no support by phone? Could be some kind of dirt or contamination, the transformer could be shorting or sparking, write me at [email protected] or look me up on allexperts.com, it may be worth mailing to me and let me estimate repairs,
2answers
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
