SOURCE: my phone htc p3450 touch shows low memory
HTC gives the same problm if u use internet alot... try deleting the cache n cookies n all the history every time u use the internet and try not to save anything on the phone memory... helpz alot
SOURCE: HTC Touch Phone is hung up with the following message:
I've got the same problem and I finaly succeed to fix the problem.
Here is how to proceed:
1- push the upper side "power button" and the right side "Photo button" at the same time with one hand (yes, I know it's hard ;-))
2- With the stylus, press the reset button (the hole at the lower side)
3- Before the evil message comes up again, put your stylus down and press the central button and the left directional button simultaneously, keeping the two buttons of action 1 pressed (it's besome harder!)
4- If you succeed to press this four buttons for a while, your cell phone should come to life again!
The good thing is that the flash memory has not been erased and the previous content is still available.
The bad thing is that my "Photo button" is now unusable and each time I press the "Power button" it acts as the "photo button" did before.
The solution is to associate "No action" to the Button#1 in the configuration menu.
Another side effect: each time I press the reset button, I've got again the evil message and I have to proceed like above to recover my phone.
Well I hope this will help you.
Regards,
SOURCE: I need internet and mms settings for htc s620
Hi...
Why don't you call or sms the customer-service of your provider?
they will send you an sms with the settings for the phone.
friendly greetings, Gilbert.
SOURCE: Free virus download for my HTC Touch P3450 Smartphone
hello
kindly go through this link and over here you will get all the anti virus software and other software as well
SOURCE: i have problem with vodafone gprs settings on my phone(htc touch)
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Regards.,
Jay
