If compressor is not shorted out to the ground and between each leg of compressor multimeter reads resistance You could try to install 3 N 1 hard start kit. But most likely compressor is weak, be prepared to replace compressor soon. Here is my situation on this compressor - everything was running, but compressor. I check for short and resistance on windings - everything shows that its a good compressor. Installed Supco 3n1 kit. Unfortunately it did not help - need a new compressor.
It could be your compressor not running. A couple of things could cause that. There could be a capacitor for the compressor that is bad. The contactor for the compressor may not be working. The compressor itself maybe shot. If you have a multimeter you can check the winding resistance of the compressor. If it checks capacitors you can check that too. Sometimes a low refrigerant charge may keep it from coming on.
