" " I don't know what buttons I pushed, or whatever... and I cannot locate the manual... but the caller ID does not display any longer, and when I I press the CID button to display the Caller ID list, it keeps telling me it's empty. I have watched the phone as it is ringing, and it just tells me that the phone is ringing, and displays NO Caller ID in the window of EITHER of the 2 handsets. I KNOW I still have Caller ID through my phone service provider, as the CID displays on my "wired" phone in the bedroom AND on my TV screen through DishNetwork. So it's not like the Caller ID is not coming INTO the phone system.
Panasonic KX-TA624/824 automatic Caller ID logging
How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824) System Programming:
In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
The Caller ID Indication button will light up only when the system has logged UN-answered calls.
Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
You can erase the entire Caller ID log by pressing Intercom, then 70**#
You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
I you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program.
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
Select the Button Programming button. The Button Programming window appears for the selected extension.
Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
Select the Caller ID Name Display button.
When you are finished, select the OK button.
Repeat steps 5 to 7 to program other buttons for this extension.
1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu. 2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display. 3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting. 4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
The way to erase all calls on the cidco cw99 caller ID is to arrow into the caller ID list and hold the Delete button for about 6 seconds. The screen will display "- NO CALLS -"
Note: it does not matter which Caller ID entry you arrow to before you hold the Delete button. This also works if you are on the "- END OF LIST -" screen.
If you want to delete a single call, arrow to that call and press the Delete button twice.
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in. That caused it to "reboot" the entire system, and the CID now shows itself.
