Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
Check the fuse or circuit breaker for the outlet you now are plugging into.
Check for power at the outlet with a voltmeter, not test light or "hot-stick" as they tend to give false readings.
Example customer complained hid window a/c would not run he sais building maintenance checked outlet with "hot-stick" which showed good.
I tested with a volt meter and showed no voltage.
Outlet had broken neutral.
fixdit4real 1 solutionsJun 15, 2011
Ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Is there a fuse anywhere that I need to check
