Expert
- Posted on Mar 25, 2008
Re: internet connection of psp
To set up Infrastructure Mode on your PSP®:
- Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
- Highlight (Settings) from the home menu.
- Select (Network Settings) and presinternet connection of psp - icn_btnx_color.gifuploads/images/icn_btnx_color.gif" alt="icn_btnx_color.gif" class="h_mi" />.
- Selectinternet connection of psp - icn_btnx_color.gifde and press Select New Connection and press .
- Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue. For more information, see Using the On-screen Keyboard.
- To set the Service Set Identifier (SSID) for the access point, select one of the following:
- Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
- Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
- If you cinternet connection of psp - icn_btnx_color.gifion in the previous step, select the access point to be used and press .
- Confirm the SSID and press the right directional button.
- To enter security information for the access point, choose one of the following:
- None: does not set security information.
- Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys.
Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
- After entering the security information, press the right arrow button to continue.
- To select the address setting method, choose one of the following:
- Easy: the following information is automatically set
- IP address settings: Automatic
- DNS settings: Automatic
- Proxy server: Do Not Use
- Internet browser: Do Not Start
Note: Most home networks will allow you to use the Easy address setting, which is recommended.
- Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
- After selecting the address setting method, press the right arrow button to continue.
- Check the settings, using the left arrow button to rinternet connection of psp - icn_btnx_color.gifscreens to make any necessary corrections.
- To save the new connection, press .
- To test the connection, select Test Connection and press .
- If the connection is successful, information about the network connection will appear. Press to end the connection test.
i have my psp for a very long while now but i never was able to get through with internet
it says that there is a connecton error has occurredthe attempt yo obtain the ip address time out
It keeps saying the connection is timed out.
Every time I test the connection, even after using the correct wep key and having 100% connection wireless signal status from my wireless modem, the psp states that a connection error has occurred. and that the connection to the access point timed out. at some occasions the psp states that the access point could not be detected.
keeps coming up with timed out ip adress failed! what is ip adress?
my psp keeps saying "a connection error has occured the key in formation exchange timed out"
i can't even get a connection to my psp
I do what it says like go to settings and network and after i do all the steps it doesn't work and it getting me fustrated. how can i get internet on my psp lite version 3.90.
I need help. PLEASE!
its anoying
it keep telling me no access point where found
my psp is still not working cant connect it said ip address is timed out
my ip adress i need a new one but i dont have the psp manuals
my ip adress i need a new one but i dont have a psp manual
