Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Jan 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lawn tractor shuts down when it gets hot it has been happening for the past couple of years it is now more frequent. I just let it cool off and mow a little til it shuts off again. Neighbor said it may be the coil needs replaced he doesn't have tools to replace it though. Any other suggestions
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Craftsman Master 1,669 Answers
  • Posted on Jan 19, 2018
Clyde Ottaway
Craftsman Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490746
Points
2465
Sounds like one or more of the spindel bearings is seizing up when they get hot next time it does that feel the spindels if one or more replace it or just replace the bearing much cheaper
5 Related Answers
Bob B
  • 272 Answers
  • Posted on May 10, 2009
SOURCE: JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 06, 2009
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 14, 2009
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Anonymous
  • 218 Answers
  • Posted on Jun 30, 2009
SOURCE: Scotts lawn tractor idles wide open.
Hey Russel..my name is Keith..and it sounds like your throttle cable hold down clamp has come loose..can you check that..and if its all secure...please write me back and we will look for another solution
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jul 05, 2009
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Husqvarna YTH2348 just quits while mowing...
check the coil on it,not a fuel problem if the coil gets hot it will shut down and when cool cranks back up,my dad is a lawnmower mechanic!!!
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
4answers
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
3helpful
2answers
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
1helpful
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
2answers
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at [email protected]
Engine cutting off
Depends on how it cuts off. If it gradually slows down over a few minutes or surges, it's likely the carburetor needs to be cleaned and rebuilt. But if it's an immediate cut off, it's likely to be a safety switch such as the one that shuts down the engine when you get off the seat if the mower is running. Sometimes this happens frequently to a light person who bounces on the seat when mowing.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
