Question about Stoves 720EF Electric Double Oven
Simpson Apollo can't set clock so oven won't work
Simpson Apollo stove can't set clock so oven won't work . Don't know what model it is but is has a ceramic top, it's a thermowave and has 5 buttons under the clock
  • 1 more comment
  • Anonymous Mar 17, 2014
    How to set clock simpson gemini 1U604W*00
  • Agaton
    Agaton Apr 30, 2014
    hello lovely people I have uploaded manual for simpson electric cooker herehttps://www.mediafire.com/?z2j7boza31l8p...
  • Agaton
    Agaton Apr 30, 2014
    just give it a few second to refresh
  • 250 Answers
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on May 29, 2010
  • Hereweare Dec 24, 2011
    Thanks parsonM for the help - I was able to adapt your instructions for an older model Apollo and fixed my problem. What did we do before the Internet?
SOURCE:
My oven doesn't work its a simpson apollo and it got 6 buttons under the clock
Hi,just food for thought,is the lights flashing if so you might just have to set the time,if there are no lights flashing has the cooker got a plug check the fuse has not blown.
Jun 08, 2016 | Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
I have an old Simpson fabulous 300 bench top stove in our beach house. We are unable to get the oven to work at full power. We have fiddled with the timer dials in the past and always get it going but it...
First of all, thank you very much Lindsay for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately a User's Manual for that particular SIMPSON appliance is no longer available.
However the problem is most likely that your TIMER has been set to AUTO which will prevent the oven from functioning. The timer needs to be set in the MANUAL mode.
Here are a few links to some other online resources which describe the various procedures for setting the clock and switching the timer mode which may help with your particular problem:
http://reviews.ebay.com.au/Things-to-check-if-your-electric-oven-won-apos-t-heat-up?ugid=10000000001213735
http://john.daltons.info/appliances/Simpson%202001%20Instructions.html
http://product.electrolux.com.au/Public/File/14880 (SELECT OPEN FILE)
http://www.simpson.co.nz/FAQs (SELECT ELECTRIC COOKING FOR APPLIANCE TYPE)
http://www.ehow.com/how_7382695_set-timer-simpson-wall-oven.html
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above. This will open a new web browser page automatically for you and allow you to view the information at the websites indicated.
I truly apologize Lindsay for not being able to provide you with the exact support documentation that you requested, but unfortunately on occasion the desired material is simply not available online.
I still hope this was at least somewhat helpful to you.
Good luck and take care.
Joe.
Jan 15, 2012 | Stoves Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Have shifted house, my Simpson Apollo ceramic oven won't work. The elements are fine. The timer and auto lights are flashing. I can't seem to make it stop. I have no user guide to help fix this error,...
The timer needs to be set to manual mode for the oven to work. Turn the oven control on. Play with the buttons on the timer. Try all combinations. It may take 5 or more minutes. When the oven indicator light comes on you will know it is on manual and the oven is working.
Feb 26, 2011 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Stoves 720EF Electric Double Oven Logo
8,021 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
