Nuvi 660 remains at initial screen ("GARMIN" in top left corner, "nuvi" in the center). Have attempted reset, software update (program says something like "update corrupt"). It won't show in My Computer, and only shows up in the update software when continually holding down the Power key (the screen displays "pre-boot mode" during this).
SOURCE: voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
SOURCE: garmin nuvi won't turn on
Well , do you delete or add something in your NUVI before that occured.
Need more information.
Is that a new problem ?
What is the lassfrimware update ?
SOURCE: garmin nuvi 660 personal travel asistant
Do you know how can I do hard reset in Garmin 660
[email protected]
SOURCE: NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
SOURCE: Garmin Nuvi 660 dead battery?
Normal
0
Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended
by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny
torx screws on the antenna. Remove them and carefully seperate the antenna
housing. Pay attention to how the antenna flex is seated because reassembling
the antenna housing can be tricky. On the left bottom side the pin assembly
that holds the antenna in is spring loaded. Pull the pin towards the center and
you will be able to seperate the antenna housing from the unit. Underneath you
will find two more tiny torx screws holding the main housing togather. Remove
those two screws and you are almost home. Now you need the special plastic tool
that you can get on ebay. The tool is used for opening ipods without mangling
them. Gently pry the case apart with this tool. Start where ever it is easiest
to get the tool in. Once opened you can figure the rest out for yourself. The
battery is flat and rectangular and is seated behind the circuit bourd attached
to the back cover.
Same problem
