DTY 4000 tractor dies when engaging pto, new belt, spring, blades and now a new PTO switch. No clogging and blades turn freely.
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Testimonial: "Hit on the head with such a simple solution"
Thank you, That worked
Checked switch and relay have new relay, PTO will not come on relay bypassed then blows fuse
