SOURCE: amana adb1500aww3 dishwasher will not turn on
amana dishwasher keypad has power BUT lights are dim and will not work. tried doing a rest and nothing.
SOURCE: I have a Amana dishwasher
Hi More likely the problem is a bad
control panel. The chance for the control board to be bad is relatively small. Also
the most common cause of a unit having no apparent power and not starting is a
door switch not closing or the contacts in a door switch not closing. http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#itdoesntworkatall
Please check this link to get a detailed idea related to your issue:-
Please get back to us if you have further query else please accept the
suggestion.
Thank you for contacting fixya.com
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
