ASUS M4A78T-E Motherboard with AMD Phenom II X4 955 Quad Core Processor Bundle (M4A78TEX4955BLACK) Logo
Anonymous Posted on Apr 30, 2010
Can i put a AMD Phenom II X6 CPU in a ASUS M4A78T-E
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on May 08, 2010
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301468
Points
2783
Is the Am3+ socket also possible for sapphire AM3RS890G2?
am3+ socket is what the socket is listed on the motherboard, so if you have a CPU that fits only AM3+, the CPU wont fit it unless directed by the CPU manufacture seeing that AM3+ is for AMD processors only if you have a older AM3 CPU it might fit the AM3+ motherboard if listed, this paticular model only lists AM3 and fits Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6
2helpful
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Can AMD Phenom X4 9650 Quad to use in motherboard Asus M4A78T-E ?
Yes your motherboard supports AMD Phenom X4 9650 Quad. However you need to make sure your BIOS verson is greater than 1503. if not you need to upgrade your BIOS.
Caution: Update your BIOS if its absolutely necessary and at your own risk. Wrong move may spoil your motherboard.
Hi, I am having an issue where upon waking my computer from standby mode (S3), there is no display and fan speeds become irritably loud and fast. I have no choice but to turn off the power from the back of...
if you did not used heat sink paste between the heat sink and the cpu unit, that, will be you problem initially
the paste is used to exclude any air and gaps between the cpu back and the heat sink and makes a perfect heat transfer medium
cpu units will hit critical temps within seconds if the heat is not being transfered correctly
1helpful
Sounds like a procie problem.
Check your processor's heatsink, if it really sits flat on your processsor.
Try to replace with another processor, take note of your socket if that is for the board's requirement.
Put a new heatpste too.
Then tell us the effect.
Thanks for using Fixya!
1helpful
2answers
AMD Phenom-II is installed in Asus M4A78LT-MLE motherboard. While system is booting showing error message -" This CPU is not supported by this model. Please check CPU QVL on Asus website" Please...
the only phenom-II cpu's it supports are the 545 and 550 socket am3 1.01ghz. if you have anything other it will not run. here is complete cpu support list here
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
Can i put a AMD Phenom II X6 CPU on the mobo
Check their website or send them a support ticket. They'll likely give you a better answer than what you'll get here.
If not, they might update the bios so you can.
How to set asus montherboard bios
keep pressing del as u start the pc u will see the bios
as far as GPU is there u can do it from the bios for overclock related thing and for other thing u can do it using the windows
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
