Question about LG 24 in. LDS 5811 Built-in Dishwasher
We have an LG lds5811ww dishwasher with IE error
We have an LG lds5811ww dishwasher and we are getting an IE error. Looked it up and says its a water inlet problem. Cleaned everything out, checked hose, all good, Sounds like water is getting into the machine, but after about a minute the cycle stops and the error shows up again. Help please and thank you.
  • 1 more comment
  • lizellis65 Apr 30, 2010
    Thanks...We'll try it and let you know.
    The machine is filling with water...no problem with water inlet. The IE error code then comes on...and when I checked the tub the water level seemed to be quite high, it was "lapping at the edge of the door". Perhaps the error code was coming on in order to shut off the water input? Perhaps there is a problem with the water shutting off at the right time? Also....when I restart the machine, it begins by pumping out the water in the tub, then begins to fill once again until the IE error code comes on again. Does this narrow down possible problem? Thank you.
  • lizellis65 May 05, 2010
    Found and cleaned water level float and sensor....problem still exists.
  • 1,998 Answers
Check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Posted on Apr 30, 2010
  • 1 more comment
  • Rick Ead
    Rick Ead Apr 30, 2010
    did you inspect the wires at the bottom of the door?
  • Rick Ead
    also theres a float switch that connects to the bottom of the tub when this is high enough its supposed to shut your water off the float is on the inside of the tub folow the float to the bottom and check the switch t be sure it is good
  • Rick Ead
    Rick Ead May 05, 2010
    i had t his problem also occur on a bosch there are filters inside of your valves remove eachone and inspect them the smallest partical of debris can give you this error code on a bosch it willgive you the check tap error code here is a site the should also help u with this problem http://lgknowledgebase.com/kb/index.php?...
SOURCE:
Water not hot enough
Before you start dishwasher on your sink start the hot water then after you start dishwasher then you can turn sink off. Hopefully this will help.
Nov 17, 2013 | LG Dishwashers
LG DISHWASHER LDS5811WW HAS ERROR CODE LE.WHAT PART DO I NEED?
check for broken wires... if still cant find the problem take motor off and spin the shaft. if there is resistance then you need a new motor
Aug 08, 2010 | LG 24 in. LD-12BW5 Free-standing...
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
OE Code keeps coming on screen LG Dishwasher LDS5811WW
OE error message is listed in the manual as a drainage problem so first I would check for a clogged line
Jan 28, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Parts breakdown for a LG dishwasher LDS5811WW
Yes. If you disconnect the water line from the dishwasher you will see a screen inside the inlet to the water valve. This should be a Fix-Ya for your dishwasher. Thanks for the question.
Dec 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
I have a LG dishwasher model # LDS5811WW is there a filter of some sort at the water intake? My water has be known to have sand in it . The dishes are not all washing some are some aren't.
No filter in these units. It is possible that sand has gotten into the sump assembly and is not allowing the vario motor to properly switch between the upper and lower spray nozzles.
''IE'' error code on my LG dishwahser
According to the owner's manual it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
Nov 15, 2008 | LG LDF6810 Built-in Dishwasher
Dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
645 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
